saltchuckmatt
- Jul 19, 2019
- 3,168
The choke mechanism should move up and down with your finger with Little Resistance. It would appear that that ny- tie is holding it open. Can't tell from those picture angles. The motor has been rewired to fit the red plug box but might not be wired correctly for the choke. Apply 12 volts to the choke solenoid wire and see if it moves. I believe your problems are elsewhere lots of work to do to this motor.
