ratdude747
- Sep 30, 2023
- 447
It was already there when I got the boat... No audible bolt grinding (nor a loose starter) so presumably there's no issue.Yes most folks are converting to PMGR for weight savings and easier install. Only issue I have heard is sometimes the PMGR is slightly shorter than the original and you need to get new bolts, which is not a bad idea anyways
If it wasn't a marine rated unit, I'd be swapping for something due to the fire hazard. But it is marine rated and I was able to fix the wiring mistake, so I seen no need to fix anything else that isn't broke in this case.
