1983 Johnson 35 H.P.
iggyw1
Ensign
Hello again,
I am going to get the control cables for my remote box to the motor replaced. I have a side console with remote throttle and gear cables, side wall mounted control box. I currently have very long (too long) cables on the boat that I purchased, and I am going to pick up a new set of 12 foot cables for it. Just wondering what is a fair price I can expect to pay for a mechanic to remove the old cables and install the new shorter cables for me, NOT including the price of the cables, but just for his labor? Thanks.
tphoyt
In my area it’s $100 to $125 an hour. One hour minimum.
It is a simple job that you can do yourself.----You must be willing to try and follow instructions.-----Get the correct cables first.-----Picture of your control box ?----Is it single lever or 2 levers ?
iggyw1
Ensign
Did you take your cables that are to long and make a big hoop near the motor? Lots of people do including me.
Yes, There is a HUGE loop in the cables and they are in the way right now actually. I think they are probably about a 16 or even 18 feet long. I don't know why the previous owner used cables this long but I got some 12 footers today which will be the right size.
EDIT: There WAS a huge loop that I errored on and tied it into a tighter loop to clen it up. Was not thinking and I displaced the fast idle lever by doing that. Hoping it just came undone inside the box.
iggyw1
Ensign
I picked up some new cables today. They are 12 footers & that's what I need rounded up to give me a nice clean loop. It is the one lever type control box. No trim switch involved. I took one apart years ago and I might just try it again. I just am not sure of the motor end as I do not want to mess up any adjustments that are good right now. I made the error of tying the big loops together with some wire ties to clean up all of the long cables at the stern area, and now I got the fast idle level out of place, so I need to take the box apart anyway to make the repair. Hopefully, I did not break the nylon part in there for that lever. There are plenty of used control boxes in my area on a sales forum and they look real decent & reasonably priced if I do need a replacement.
