Scott06
- Apr 20, 2014
- 7,312
Just got done doing a reseal and a few bearings in my 2004 gen two. Pressure tested it , passed , filled it with lube and laid it on the garage floor for a month, was gonna put it back on the boat this weekend, found lube leaking out of shift shaft seal… which I just replaced.
I bought two seals, so I have a spare. when I did the seal I recall the spring side being out (water side) And that’s the way I reinstalled the new seal. Can anyone confirm it is correct Seal orientation?
additionally there were two seal part number listed for it , one superseding the other, same part number with a 1 at the end. … does none know if this newer part number is different or better? Seal i put in looked the same as the old one
