Mercruiser trim pump has a leak.
brian3127
I have a trim pump that, I noticed sprung a leak before we winterized the boat. We are uncovering the boat this weekend. I hope its just a loose fitting. but if its the tank I will have to replace it. What is a good brand and where should I buy it from.
I did a search on google and it looks like they are under $400.
brian3127
Trim pump for the Mercruiser 3.0 alpha 1 outdrive. How hard is it to replace just the tank if that is what is leaking.
Chris51280
Ensign
very simple. they did make different versions though depending on the year. has an o-ring to seal. Get the right manual and there is even an instruction on how to service the pump itself if needed
pull pump, remove cap, drain oil. turn upside down, remove single screw. throw away old tank. put o-ring on new tank, tighten screw.
remount pump
fill with oil.
not enough time to drink a beer
The reservoirs tend to crack when the single mounting bolt is too tight. So tighten just enough not to leak.
the plastic reservoir is only intended to last past the warranty period of the pump. they get brittle after 15 years due to heat, ozone, etc. my boat is on its second one since I have owned it.
while you have the pump off, its also a good time to hit the bracket with some cleaner and a rattle can of rustoleum
worst case it is also a leaking line. almost as easy to fix.
brian3127
Uncovered the boat this weekend and found that it was the tank. i was not cracked but it was leaking from the bolt that attaches the tank to the pump.
I have a new tanks with bolt and gaskets coming in the mail by the 19th. thanks guys for all the help
