SlipperyOar
- Apr 12, 2024
- 138
The previous owner didnt have the rectifier wired properly. So I opted to purchase a new rectifier and install it properly per the manual. Upon running the motor with a multimeter hooked up to the battery I instantly noticed a voltage increase. It got up to 15.1 volts and I shut down the motor in fear of cooking my battery. Is this normal while it’s running at 1500rpm? Could my voltage regulator possibly be toast or was I testing from the wrong spot?
After shutting down the motor i noticed my battery was up to 12.7 from 12.6 volts so it had a slight increase, but how can I ensure it will stop charging once the target voltage is reached?
