crazy charlie
- May 22, 2003
- 5,605
1988 Mercruiser alpha .I have a slight leak in one of the lines.Not sure if the lines have ever been changed.Boat sits in salt water 5 month of the year so i am assuming the line is not coming off easy from bottom of transom assembly and dont want to damage anything.Plan on using a brake line wrench after using some Map torch heat.How much heat is too much heat on this? Any tips to make this go easier would be appreciated.Charlie
