Grub54891
- Jun 17, 2012
- 6,419
I used to have the grease deal for lubing the front sprocket. Till I found out the hard way. The bearing went out. Found out that the grease actually formed a “dam” around the bearing and some debris was held in there also, causing it to go bad. Without the grease, the oils from the bar can lube it just fine, and helps fling any stuff out.Have never lubed a sprocket on a chainsaw. I was a C faller working woodland fire in 12 states, heated my house with wood. Never had a sprocket fail before the bar was shot. People do not realize how important the bar is to have a good cutting saw. I replaced bars every year.
