maineiac5586
Master Chief Petty Officer
- Feb 14, 2009
- 818
My 2001 130 hp v4. When I adjust the oil pump lever clip at the oil pump arm I'm having a little trouble. If I adjust it so the lever hits the pin on the pump (low speed throttle closed position) it short changes the pin at full throttle. It just about makes it to the full throttle pin on the pump. And vice versa if I make it touch the full throttle pin it short changes the idle speed pin on the pump. We are talking very small amounts between the pin and the lever. I adjusted it so it definitely hits the full throttle pin at full throttle and almost touches the pin for idle. The plastic clip that goes into the carb lever (where you flip it to lock it onto the oil pump rid) is new as well as the adjustable plastic socket for the oil pump end of the rod. My motor seems a little too smoky at idle and I'm wondering if this is the cause? I still have to fine tune the idle mix screws so that might be that. Thank you
