1964 Glasspar Seafair Sedan - minor restore w/questions.
Thirsty Endgrain
Well it's been a while, and I haven't taken much of a break from continuing to build this thing out. Figure I'd share a bit of the progress:
Had a 90hp Johnny on there for a while and recently traded up to a 90hp 4 stroke merc.
Just spent a good part of a week building a pilothouse for it too. Wanted a place for radar so I took the short easy route of building something. Probably have about 70 (physical) hours into it (and like 350 mental hours).
Getting everything all mounted in and sealed up etc, but this is about where she stands now (Except all the windows are in):
I'll post some process pics sooon!
Thirsty Endgrain
Mocking up with cardboard at night. Fun.
Now with plywood, built it all mostly out of 1/4" AC scrap play sheets I had leftover from jobs.
Had these little tails hanging out to support eaves but decided to do away with them. Would make for a gassing and finishing nightmare, plus once glassed it would be strong enough without them.
It would have been nice with a wood finish, but I wasn't building it with that in mind.
"Helper" making sure there's a coating of thick hair embedded in every nook and cranny.
Finished! Used rustoleum topside primer and paint. I really wanted to spray it but I didn't want to have to build a spray tent, filter and ventilate it etc. Had to do all the work in my "house" which is technically a "garage" hence you see that I'm simultaneously finishing the walls.
Doing the wiring etc now, mounting vhf antenna, nav lights, rod holders etc. I probably have just under $1k into it. Had a half gallon of epoxy and all the ply, some 1708, plus some of the plexi for the windows to start, but had to buy more epoxy, fiberglass, fairing compound, paint, plexiglass, the rod holders, stainless rail to mount them, and some odds and bits. Will update more photos once I carve out time to finish.
Thirsty Endgrain
Just found your thread. Any other updates to share? Where did you find your bow rail?
Not much to update, little things here and there but it’s basically as the last pics and everything are shown. It came with the bow rail, I believed it to be stock but maybe someone added it…
