1985 Century Mustang
- Mar 9, 2023
- 611
When the rabbit ears are on and the engine is running and the temps are normal, does this mean my outdrive impeller is also functioning?
Not necessarily
The muffs force water in under pressure
The true test is if the impeller can move water when the boat is in the water.
On mine I usually run the impeller 3 seasons or so. With a 160 stat my running temps are about 160-170.
It should be fine unless it was a cheap aftermarket one. Stay with oem impellers . In fresh water I get at least six out of mine .Thanks, I'll be testing it out shortly. I replaced the water impeller last year, hopefully it held up.
Ha ha, like those tootsie roll commercials, none of my outdrives has ever stayed together long enough to have a worn impeller, and I replace them whenever I crack open the drive.It should be fine unless it was a cheap aftermarket one. Stay with oem impellers . In fresh water I get at least six out of mine .
I believe 145-160 is where you want to be. CharlieI took her out today and the temps stayed in the 120-130 range, the impeller seems to be working fine. The water temps here in NY are about 76 degrees.
