JohnnyGuy
- Aug 24, 2017
- 195
So I am working on a friend's '86 Johnson 6.5hp commercial motor.
I've replaced spark plugs, all the fuel lines and I did a carb kit on it, it I've got a few questions on this motor.
It's my first time working on a 2-piece plus bowl carb. The slow speed needle is at the top and front of the carb and I've got it set 1.5 turns out from lightly seated.
The motor will run for a bit then shut off and is a bit troublesome to get started again.
There is no neutral stop and there's no starter pawl stop so you can pull start the motor in any throttle position. I'm not sure where I should have the cam follower on the armature plate when starting... there's also no low speed stop so you can just twist the throttle down and it'll die out.
Is there a link to a description on how to do a link and sync on these motors somewhere? Apologies if I've missed it. There's an adjustment screw on the cam follower and on the cam. Also there's a metal screw on the port side of the carb that has a spring on it for the throttle body, is there a setting for this?
I believe my issue MAY be the fuel pump because I noticed that the inline fuel filter on the port side of the motor wasn't full of fuel (there was always air near the top (outlet side) of the filter. When pumping the fuel primer bulb on the hose from the tank, it definitely ran longer but I still couldn't get this filter completely full of fuel, aways air at the top (maybe that's my issue?)).
Another note is when I first started it, it seemed to be intermittently missing, I swapped the powerpack from another spare I had and that seemed to have made it better...
Any help/suggestions would be appreciated.
Quick test video
Thanks,
JG
Quick test video
Thanks,
JG
