jimmbo
- May 24, 2004
- 14,239
If the Original Carb was getting Gummed Up, and not staying Clean, how is a Different Carb going to be any Different?
You choose a Prop by making sure it runs in the WOT Rpm Range stated for the Particular Engine, which in your case is 3800- 4200 rpm.
You DO NOT Prop for Targeted Speed at any RPM. Several Props will likely get in the WOT Rpm Range, and they may have different top speeds because of things like # of Blades, Blade Area, Pitch and Dia, Rake and Cupping. Maybe amongst the choices, you will find a Match that is closer to the Speed(s) you want, but what ever Prop you Pick, it has to run in that Rpm Range at WOT, if you expect to get any Engine Longevity, and reasonable Performance
As for the Electric Choke. It should be set to just fully Close at a Temp of 75F. If your Leaving the Key on too long before Starting, then don't do that. If the Choke was correctly Set Initially, and you change that, well somewhere along the line you will have created a New Problem
