cyclops222
- Mar 21, 2024
- 3,218
1 &2 should be normally closed at rest, 1&3 will be normally open at rest.I can't figure out which one is the common. #2 is NC and it says the other two are no. Can you tell which one is the common?
How much metal came out of the oil pan? would keep changing and cutting filters openPurrs like a kitten. Thanks for your help!
test with an ohm meter across the terminals. if they are not marked you may be on the wrong terminals, maybe metal from oil passage got pushed into switch?My fuel pump is now pumping if the engine quits. Even after oil pressure has dropped. I'm suspecting a faulty switch. One of the terminals wobbles. But I want to double check my wiring. I
The terminals are not labeled on the switch. I do have a diagram of the switch terminals. But I don't know which one is the common. How would someone figure that out?
