wvmedic
- Jun 3, 2008
- 534
Hello all.
I just bought a SS 181 back that I bought in 2009. It has went through a few hands, deck has been replaced and needs it again. I am not sure what ply was used or if there is any flotation in it. The previous owners have really jack legged a lot of things, using drywall screws, tapacon screws and the like, heavy silicone around the windshield, what looks to be house paint on the hull.....
I am slowly tearing it down, used some citristrip on a section of the hull and it appears that is going to work well.
So trying to formulate a game plan and decide what I am going to use on the deck. I'm thinking ACX over marine grade. Another thing I haven't decided on is sealing the plywood. I was going to epoxy it, then reading on here about the possibility of it cracking and allowing water intrusion. I've thought about the Old Timmer method, I will be using nautolex vinyl for the floor and sides. I'm not sure what glue would stick with the Old Timmer's formula though. Then I thought about leaving it as is and just putting the vinyl over it. I've read many threads involving the OTF but only one with putting vinyl over it and there wasn't a clear resolution as to what glue would work.
Any suggestions from the seasoned here?
I'm 56 years young and I only want to do this once. The plan is to make this a Walleye fishing boat on some decent size Canadian lakes. I think an OB boat would have been better, but the 181 is what I found. We will mostly use it as a pleasure boat here in WV with some fishing involved.
Thank you, Jeff
Thank you, Jeff
