saltchuckmatt
- Jul 19, 2019
- 3,109
Yes, you said that already.
Well it is not broken but it does not look round at the tip like the one of your photo. It looks like its tip is flat. Both carb needles look the same...Could your needle valve be broken...? Part 18
I live on a Greek island. Every boat part shop here suggests I buy a different brand engine.... Anything except Selva.The came roller should be readily available.
What’s your location?
E Bay and Amozon likely have them.
If your homemade cam roller dimensions are off likely everything else will be as well so book specs aren’t going to help. Jmo.
About the needle I can assume that some previous mechanic changed it from another engine and I can accept that it works at 5,5 turns instead of 2,5.Your motor is an elegantly simple machine.----Shops are only in business to MAKE MONEY.----Many do not care to help out a customer to improve their reputation.
Yes, I readjusted all that according to the service manual. Now when idle there is no pressure to the carb roller and both carb horns are snap closed. They move in sync when I open the throttle...Perhaps the needles where screwed in to far and they were flattened.
Not sure if you can see this but there are other adjustments. Did you loosen the screw on the carb just below the idle circuit?
No, there was the original orange glue on the top nut so I didnt touch it.....Have you pulled the flywheel? If so besides looking at the key you could see if the plate is not moving back all the way.
More pictures of all sides of the motor might help to see why this is not working per factory specs.
That link does not work and I cannot find a video for a 2005 40 hp engine
Update.About the needle I can assume that some previous mechanic changed it from another engine and I can accept that it works at 5,5 turns instead of 2,5.
The thing that buffles me is the suggested idle position of the roller in conjunction to the position of the idle screw that is supposed to be 1/2 inch. This is not mechanically possible. Only if a part like the throttle plate or the spark lever is not the original one ......
Well I have spend countless hours reading and working on this engine to make it run as it should. I feel I have it at a good point even if some settings seem to vary from the manual. I am going to try the boat at sea.
If it runs as good as it does with the muffs and performs well in all the power range I am not going to mess with it any more....
