thedinz
- Jun 29, 2014
- 153
I have already ruled out the wiring and the fuse, its all correct. The only next thing i can think of is ti pull it out and see if the automatic feed is blocked with crap? But very much NOT easy to get to.
Any other suggestions? It works fine when i hit the switch manually and as i said its wired properly to turn on on its own, it just doesnt.
Its a rule 1000 i beleive but an older model, because of how hard it is to get to i went on ebay and found the same one bran new so that i could seat it inside the already mounted bracket, as they tend to change brackets on newer models. But it was all working properly when installed, over time the automatic feature just doesnt do its thing anymore, which is dangerous.
