exhaust bellow off again
liusigou
Last friday my boat had the maxium speed of 33m and yesterday it run very slow only 9m and I found the engine side of exhaust bellow was off and the outdrive side is still good. It seemed I lifted the outdrive too high. How can I adjust the trim limit & sender to make the outdrive not to be lifted too high.
Also can I mount the exhaust bellow without moving the u-joint bellow because it is in good working condition.
alldodge
Don't know what drive your working on other then a Merc type
The trim limit sender is on the port side of the gimbal ring. Loosen the screws and adjust. If the limit was working and now it doesn't most likely it will need to be replaced
The exhaust bellows is not needed other then for sound reduction
With it being torn it can be replaced by removing the drive or just don't worry about it
The other side of the issue could be with the exhaust bellow tearing it might be time to replace all the bellows before the U joint tears.
Do you pull the drive every year to inspect boots, gimbal bearing and change drive lube?
liusigou
I have just resealed the exhaust and u-joint below two week ago. nightmare. Is exhaust bwllow mandatory? Somebody mentioned it us full of water while boat is in the water. my boat is Mercruiser 1989 2.5l 120 hp
alldodge
Exhaust bellow is full of water when sitting and is not necessary or mandatory
The Bravo 3 drives don't use a bellow they use exhaust TUBE
Pmt133
I've almost always run the tube. Not running exhaust bellows is the marine equivalent of cutting the muffler off your car. It doesn't hurt a thing but may get louder. The tube is a compromise between the two as some exhaust is still directed out the leg but it's so freaking easy to install. The V engines are fairly quiet with or without one. The 3.0l I had, everyone nearby knew you were using a tube instead of the bellows.
liusigou
But I do not know why my boat slow down after the exhaust bellow came off. Is it possible that broken bellow has changed the water flow direction and lead to the slow down of the boar?
alldodge
The exhaust bellow should play no effect on how the boat runs. Check inside the exhaust tube coming from the motor to see if something is clogging the exhaust
