2007 Volvo Penta 5.0 GXI-G, Fuel & Spark, but No Start
ShipShow
Hello all,
I’m stumped and have been surfing the forums but haven’t yet found another issue like mine.
The Long story: I lost power steering while on the lake. Limped to a marina to find someone put a silicon vacuum line cap on the return port on the reservoir which cracked, throwing power steering fluid all over the belt and engine compartment. Was able to correctly fix the PS leak and replaced the belt (and impeller too since I had to get that deep to change the belt). Ive always noticed oily scum in my bilge and engine compartment and with this mess, wanted to clean it all out. I covered the distributor, ecm, and most important connections with a rag and spays foaming degreaser on the engine from NAPA. I then rinsed lighly with shower setting from garden hose and cleaned the rest of the engine compartment and bilge. I left the engine compartment open for a couple days to dry out. (All of this was done with the battery out btw)
We backed it into the lake and it fired right up and ran normally for about 1-2 minutes. Long enough for me to check for leaks and that the new belt seated properly. When I went to back off the trailer, it sputtered and died. Cranked and cranked. Some times it would sputter like it wanted to fire but never completely fired again.
Brought it home where it sat for a few days before I had time to work on it. Hooked it to water and it fired again right away and ran good for about 20 seconds. Then died again. Again, more cranking and no start. Verified spark to all plugs (and plugs look good too). Verified fuel pressure at ~60psi when ignition on and ~56psi when cranking. It will run on starting fluid but never takes on its own fuel. I did check the injector connections with a test light and thought it was weaker than I’ve seen in other vehicles, but was lighting. I checked the crank and cam sensors, and both connections were dry and looked good (no corrosion). It is my understanding I wouldn’t have spark if there were issues with those sensors, so I ruled those out, but I could be wrong.
My only guess is the ecm isn’t suppling enough if a signal to the injectors for them to open. Any experts out there that can send me down a couple other paths that may lead to some success. The boat has always ran great prior to this and when it has fired, runs smooth.
Thanks in advance for your help!
ESGWheel
Master Chief Petty Officer
Springboarding off the idea of fuel starved (even though you checked the pressure), here are a coupe of thoughts: Check the fuel filter is tight (vs. slightly loose and sucking air after a short period). Pull the fuel rail pressure regulator – if it still has a screen (vs. the E Clip), does the screen got lots of debris (specks of black) indicating a contaminated fuel system (infamous paint inside the fuel pump). Check proper venting of the fuel tank (try running with the cap off). Check the anti-siphon valve for proper operation (if you have a 5-gal gas can, perhaps run a new fuel line from the pump to the bottom of can > this will eliminate the valve, pick up tube, venting and the fuel line itself). Hopefully something like this (mechanical vs. ECM).
ShipShow
I'm still stumped here. The injectors aren't getting a strong signal to open, if at all. I believe it something in the ECU or hopefully a grounding issue. I've searched for an hour on the internet for an engine wiring diagram for 2006/7 5.0 gxi-g. Does anyone have one? Or can point me in the right direction with a link? Just want to track down grounds and power leads to make sure they're all good before I take it to the shop. Its frustrating because it ran absolutely fine BEFORE I cleaned the engine compartment and bilge.
Thanks all for you help!
ShipShow
Nevermind, I found one.
alldodge
Injectors are supplied on one side with 12V, the ECM applies a ground to the other side to turn then on/off
With key on, motor off there should be 12V on both sides of the injectors because the ECM is not applying a ground
Saying it will start on starting fluid but not off the gas, then injectors are not firing. This can be caused by a blown fuse or relay (on the motor), ECM, Crank sensor
