- Mar 8, 2009
- 43,544
I have not ever done business with EMP
Has the fuel pressure gauge had the air bleed out of it?
If it has then Try another test gauge
Again we are talking about simple stuff. The correct HP pump can produce more then 60 psi, the correct Reg will reduce and hold pressure real close to 43 psi.
Is this a QS pump or EMP pump?Bad fuel pump out of the box from quicksilver?
Pump/cooler kit installed
Fuel Cooler & Pump Kit | EMP 1397-97004
