120VAC NC Remote switch
alldodge
Looking for ready made but new design is OK
Issue
Would like to remotely turn OFF/ON a 120VAC circuit for 500FT clear line of sight. Have security lights on my barn and at times want to turn them ON and leave them stay that way. Security lights once it's dark can turn them OFF/ON and time or two and they stay on till sunrise
Current
Installed One of These but after install found out it is normally open and not closed. So it's just a matter of time before the relay burns out and nothing works. Only need about 5 amps because spots are LED
briangcc
Would a smart outlet work? Cause I've seen them up to at least 15A.
I have a few elcheapo's I use for christmas lights and also to turn an aquarium light on/off on a program. Just needs 2.4Ghz wifi (at least the ones I have).
dingbat
What problem are you trying to solve?
I have a motion activated lights at the barn.
Love/ hate relationship until I found a light that you could take in and out of manual mode from the switch.
Flip the switch on and of quickly puts it into manual mode.
Flip the switch on and off again, put it back into "sense" mode.
Besides that, I cheated.... the power to the barn lights is on a 3 way with the switch at the back door.
alldodge
Barn is metal and would need to run some kind of wifi out there to use them
The barn has 2 motion sensor lights, and the off back on thing is what I'm doing now with the remote switch to keep lights ON. The issue is when power is removed from the breaker panel as when lighting strikes or anything that causes the issue, the remote unit needs to be manually turned back on.
If I can find a normally closed remote relay, then the remote would be used to turn it off, instead of on.
alldodge
Hey, thanks guys
I was thinking along the line of adding another relay like Scott listed, but like the all in one also.
alldodge
Bought 2 of the carry mart switches and it's doing the same as the other one I had. Turn off power and have to press the remote to get power back to lights. Sent email to company and waiting for reply
alldodge
This was their response
In accordance with your requirements, you need to customize a product with a power failure memory function.
If you need to customize this product, please contact us again.
