Before I change the the rectifier again wanted to to ask for opinions. So I have dual batteries one deep cycle the other starting, have a 1,2 B switch, common ground between the 2 and another common across from the second set of batteries.
I changed the rectifier twice with a original Force black, then with an off the market square 6 wires. Both did the same worked one day showed 13.5v at high speed then all of a sudden 16.7v the other one has the square cgeappy and no problem. On 5his on I did buy the trigger and stator from CDI and am thinking maybe that is doing something.
The tach works fine but the 16 plus issue is bothering me. Read about it and people are split on some saying it won't hurt it and some that it is not good. Also read that using dual batteries an cause it. So on one of the batteries I have a connector switch for the fishing instruments.
Throw some testing ideas or opinions on me. Thanks in advance guys.
