killswitch917
- Sep 21, 2024
- 5
Hi all, I recently purchased myself a little project. Boat had prop and outdrive damage. I'm working on getting all that sorted out.
My question is on the inboard engine. I'm unable to get it started unless I give it some help with starting fluid. I'm not super familiar with carb engines but this is what I understand. The fuel pump does not prime when you switch ignition (at least I don't hear it), and kicks on when the engine fires up. I tried following cold start protocol by pumping the shift lever a 3-4 times and leaving it at 25% throttle. Nothing cranks but will not start. Should I be able to physically see fuel getting pumped into the carb when I pump the shift lever?
Another question. When I purchased this boat it was already winterized so I had to put some plugs and hoses back on. I also noticed these 2 electrical plugs wired into the engine harness (each side of engine) that were unplugged (pics attached). I looked around the engine, but cannot figure out where they plug in. They could be related to my no start issue, but since the engine runs fine with the help of ether I doubt it.
Any help is appreciated. Go easy on me this is my first boat. I've owned PWCs but this is my first boat.
