IS-217
- Oct 3, 2024
- 19
2008 StarCraft 1800 I/O
Mercury 4.3L V6 TKS Carb
Engine Serial #1A073605
First time posting
First time boat owner
First year boating!
Hello everyone.
Lots of great info and help on here.
Shout out to Don and alldodge for some good posts and info about what I’m trying to figure out. I think I’m on the right track. Hopefully one or both of you can help me figure this out. I’m pretty savvy but I’m no mechanic so be patient with me I’m just learning as I go here lol.
I have been reading a lot of posts on this forum mainly to do with the TKS carb system as that is my issue. The enrichment cycle for the carb won’t turn off and it continues to hiss/suck and run rich constantly.
So far I’ve tested the TKS Module it seems to be working fine other than it took closer to 20mins for the pin to fully extend when hooked direct to the battery.
The diode is no good no continuity both ways looks like it shorted out one pin is grey/burnt looking.
The 15Amp fuse - top stern side of the engine - is also blown. Not sure what this fuse controls.
I’m leaning towards temp switch from what I’ve read but haven’t had a chance to run the boat up to temp to test the sensors continuity cold vs hot.
The boats seems to run fine otherwise. So I didn’t think it would be the oil pressure switch.
It does idle high which makes sense because the enrichment cycle is running constant.
I do have some issues warm restarts and one time after pulling a tube for a while it continued to run for a few seconds after I turned the engine off, then it cut out.
So I’m looking for any and all help here to figure this out.
Why did the 15Amp fuse blow?
Why did the diode blow?
I don’t want to replace these parts until I have a good idea of why or how this would’ve happened.
Anyone have an idea?
Teach me!!!
First time posting
First year boating!
Hello everyone.
Teach me!!!
