sinkingscones
- Oct 23, 2024
- 12
Model: J15RESR
Previous owner couldn't get it to run, I cleaned carb, swapped plugs and wires, and replaced carb body cover which I found was cracked. Only thing left is cam roller missing a rubber sleeve I haven't fixed. Running 50:1
With needle idle set at 4 turns out and choke engaged (butterfly closed) I can't get it to start. It'll only start with the choke disengaged (butterfly wide open).
I'm wondering if it's running too rich, not sure what to check next.
