ttownthomas
- Jun 7, 2019
- 204
1974 Bertram 25. Twin Inline 6 Mercruiser 165's. I had the motors pulled to redo the transom and now the engines are back in -- I'm trying to align them myself for the first time. I'm struggling. One I have pretty close. On the port side I can slip in the alignment tool in until it is about 1" from bottoming out. Then only light taps from a 3lb dead blow hammer get it to bottom out. The stbd side I can only get about 3/4 inches into the splines and then it stops going in even with "taps".
Here are my questions:
Is it best practice to line it up close by eye? If I look into the stbd transom assembly with a flashlight looking through the bearing it looks like it is parallel to the bearing but low by like 1/4 inch or so. Does that mean I need to bring the mount way down?
How much side to side movement is there? In theory the aft side of the engine is fixed to the transom assembly right? I have not bolted the engine mount hardware in the the engine bed yet. Seems like I can move them a tiny bit side to side one way or the other with the dead blow hammer. Is there a best practice here?
Once i have it close, like on the port side, how much should I be turning the nut between attempts? I can turn the nut to lower or raise the mount in about 1/4 turn increments. Are we talking about moving it fractions smaller than quarter turns or is fine tuning it more like 4 x 1/4 turns?
I know its is supposed to slip in. Does that mean the tool should slip in all the way (3 fingers of pressure) until it bottoms out? The couplers are original...Dont know if that matters
