EDELCAT33
- Dec 10, 2024
- 5
I just installed in my 33ft sailing catamaran a 2022 Yamaha 25 HT with controls and lift.
I purchased a 703 control and having problems when shifting into FWD. I have no binding, but it takes a while for the FWD control to engage and when it does is quite violent and at high RPM. Once I past that, i can pull back and the rev is smooth. On the reverse side I do not have that issue but it does travel quite a bit.
So I suspect that I need to either adjust he plastic dogs at each end of the line but not sure if to make them shorter or longer. I hope I do not have to adjust the actual 703 control mechanism.
Any thoughts on this?
