I'm installing a new motor into my boat. It's a 1991 Volvo Penta 570A with a DP-A 290 outdrive.
I always overthink stuff, so while assembling the flywheel, flex plate and bell housing I decided to check to see how far the primary drive shaft (PDS) engaged the flex plate. It only in engauges is about three quarters of an inch, possibly a full inch pretty sure it's less. I replaced the bearings and seals on the PDS and think it would be impossible to install the primary shaft in the wrong position because the aft bearings position on the shaft is dictated by a snap ring, and then the bearing is driven into a seat in the housing, then the subsequent snap rings and seals go in place above that. If the PDS were in the wrong position none of the subsequent parts would fit along with the snap rings that hold them in place.
Is that normal to have such a minimal amount of spline engaugement on the shaft that links all of the engine power to the drive components ?
