Towing a 22 foot Islander that was changed from I/O to outboard on bracket.
rolmops
I am seriously considering changing the propulsion on my Islander from I/O to outboard on a bracket. This will add about 3 to 4 feet of overall length but it will also change the weight distribution. The extra weight on the rear end may also make towing unwise. I'm not talking about the trailer, Because I can easily add a few hundred pounds on the tongue. I'm talking about the structure of the boat which will now have all this extra weight hanging in mid air at the rear.
Can I still safely tow long distances , or is this asking for trouble?
jlh3rd
Master Chief Petty Officer
me using common sense says not good. compensating for tongue weight doesn't solve the condition at the rear of the boat.
I'd want to adjust my tongue weight the proper way, by balancing my boat. Balancing my boat gets me in the right direction. Can the axle/s be moved.
Then I use a transom saver....my opinion.
airshot
Gotta get the boat balanced on the trailer, probably need to move axle, if trailer is not long enough then buy a longer trailer or add on to the tongue to make it long enough. Will need more support under the transom. Very doable if you have deep enough pockets..
Horigan
I gather the OPs primary question is can the bracket handle the cantilever loads of the outboard out beyond the transom while trailering. I would ask whoever is doing the bracket installation.
I would say that the outboard ( no mention of model / HP ) is lighter than the inboard / outdrive.------I would beef up the transom and tie it to the stringers where inboard bolted on.----Move axles if needed.----Go fishing.
dingbat
Might be easier to just buy one
rolmops
Yes, I was going to buy that one. The price was right and I really wanted it. It did not sell right away, but when I was ready to buy,it had sold literally the previous day
huggyb1972
Can't speak for your boat, but mine did fine on the 1800 mile trip I made to the coast and back. My engine bracket was 34" long I braced the transom to the stringers with some angle iron in a triangle shape.
rolmops
What "Islander" exactly are you talking about?
The Islander is a 1989 Starcraft Islander 221 currently powered with a new ( factory rebuilt) 4.3 liter engine with a cobra outdrive.
Sorry about that. I sometimes just take things for granted.
cyclops222
How can removing a inboard and sterndrive cause the outboard to be heavier ? 3 times the hp ?
Lou C
Right, the I/O engine (450 lbs or so) is forward of the transom, the transom mount and outdrive probably weigh about 120 lbs. I'd say that you might need a longer trailer to get the tongue weight where it should be. Even though the OB is lighter, it is cantilevered off the rear of the transom especially if it is installed like the boat in the pix with the bracket, that pushes the weight far back, the I/O actually has superior balance.
I donno, if I were in freshwater and trailered a boat, I wouldn't think the payoff of a conversion like this would make sense. Here in the salt pond with most boats being docked or moored, sure it would.
To me the biggest issues with this idea are the unknowns of balance and handling with the engine mounted so far back, and the sheer cost of modern outboards.
You've got a reman 4.3, that can last from 20-30 years if cared for in freshwater, if the engine is clean inside, you could even add a half closed cooling system (longer engine life, and easier winterizing) so with the OB, what's the benefit? At most you could convert it over to a Merc Alpha drive system, if you are tired of hunting for Cobra parts, and a mechanic who can work on them, now that would make sense!
OB conversions make good sense in salt water regions especially the way I use my boat, with it moored in salt water from May to Nov each year. Would I do it? Nope, the most I'd do is what I said above, when the time comes, make my life easier with a reman engine, closed cooling and Merc Alpha conversion. Modern outboards are just too expensive.
