highpowerdad
- Feb 5, 2020
- 109
So, my 2005 Four Winns 190H with 5.0 GXI Volvo motor is having some stiff steering issues. I just replace the helm and cable; the steering had a lot of play. Everything is "tight" now, BUT the steering seems kind of stiff. the part I put is Dometic SHT91523, and I replace the cable and helm, it was a remove and replace, as the 20-year-old parts were the same... at least from a fit and function. It is a tilt steering wheel
Anyway, now it seems very stiff to turn, and I am only getting 2 turns lock to lock, I thought I used to get 3? I lubricated the rod end and the hydraulic piston on the motor end, it seems to maybe help, for a minute, maybe not, so really can't tell. I am going to disconnect the cable from the drive tomorrow and see if it is obvious or not.
MY QUESTION, to move the outdrive from side to side, when the steering cable was disconnected (installing the new cable) seemed VERY difficult. (I actually couldn't move it). Is there something in the pivot or transom or sterndrive end that needs to be greased or checked, where the transom plate and out drive are pinned together? I seem to remember being able to move the outdrive back and forth by hand, say a few years ago, but now I couldn't even budge it....
Will report back tomorrow when I have the cable disconnected
Thanks,
Scott R
Orlando, Fl
Thanks,
Scott R
Orlando, Fl
