Tohatsu M18d charging output
Mc Tool
I cant find any info on the charging system output . Im just figurin on battery drain verses charging input from the motor . I plan on having a house battery for my inflatable Flounder slayer. I dont care if the battery is flat at the end of the nocturnal hunt ( just get a bigger battery ) but it would be good to know if I can get an extra hour or whatev because of the outboards charging contribution .
So , does anyone know what the continuous output is ?:)
Thanks
dingbat
Thanks
What continuous output?
Small outboards typically don’t charge at low rpm. Given the size of the motor, I’m guessing 6 to 10 Amps per hour at elevated rpm.
Depth of discharge of a battery is very important to life expectancy. Discharge greater than 50% will shorten life considerably
MattFL
Master Chief Petty Officer
Thanks
Chat GPT says the standard M18D has no electrical output at all, but the M18E2 is good for 80 watts, or 7 Amps. As mentioned above, this spec is most likely at a pretty high RPM, close to idle I wouldn't expect much at all.
cyclops222
What electrical items are on all / most of the time ?
O B motor electrical amps is always at WOT rpms.
You are probably right about buying a much bigger battery. (y)
Mc Tool
There was a charging coil in there ( complete with continuity and not down to earth ) but thats all there was so I gets the Temu reg /rect and pretty much gunna hope for the best .
7a sounds useful but Im thinkin that Im mostly going to be in putt mode , was even thinkin a elcheapo electric outboard ( watersnake ) for the final approach .
I have only ever waded about in the estuary stabbin at flounders but I got my whole right leg chopped off a while ago , so the plan is to basically let the tide push me in and out with a few adjustments to keep me over the deeper channels
Boat ( Bris 3.8m .... the black double skinned one ) . Im going to plot the channels on my gps so I can stay on them in the dark .:)
Thanks slowleak , I hadnt thought of a lipo power pac , sounds really useful
cyclops222
Do not use a LIPO battery in that small boat !! LIPO chemistry batteries are the ones that burst into flames for no reason at any time.
Buy a LIFEPO4 chemistry battery for use in that small boat. They are the safest battery type available.
TIE the boat to you with a rope at all times. I have had a boat drift away. I really panicked on that one.
Mc Tool
Thanks for that , I probly would have got the wrong one .
:) With one leg , after 1 stranding I do now have a 'get home" plan sorted before I leave home in case it all turns to custard , basically dont do anything stupid . I spend a fair bit of time on and crossing the local river ( The Aparima river at Thornbury NZ, downstream is the estuary I plan on floundering ) on my quad fishing so I do have to think about the risk before I get to "adventurous" as there aint no walking home , and despite the obvious benefits of having it I usually leave my ph at home .
cyclops222
I have forgot to charge the phones the day before. I also have a VHF handheld with me.
