good day to everyone;
i'm rebuilding my 4.3 engine and i if possible i would like to recieve some info from expert people in the forum.
my original motor was a EFI 4.3 2001 due to some issue i had romoved that motor and now i'm overhauling and installing a 4.3 lx 4 barel (200 hp) and as said in other thread i'm saving and using some parts from my old 4.3 efi.
i brought all pcs in the mechanical shop for machining. i did: cilinder boor check and machining. new piston rings new bearing new cilinder planarity both head machined ecc ecc.
when i was in the shop i brought there both come shaft ( EFI and LX) and they said that EFI was better so they installed EFI one ( it should be same shaft)
now i have a doubt;
wich vlaves lifter should i use? LX or EFI?
i have 2 mai topics now, on manual i sow this 2 sentence
and
when i bought LX motor it was totally disassmebled so i don't know wich roller was going in wich cilinder, and especially direction.
and now that my camshaft is the one from EFI should i use EFI lifter accordinglly to last sentence or it doesn't really matter?
thanks
now i have a doubt;
and
thanks
