82 50 hp tilt and trim
redneck joe
If the motor pumps up under load, then the pump is probably fine. You probably have a bad control valve or leaking piston seals. Both will cause the cylinders to leak down.
Crowleymarine shows both as NLA.
As far as I know, the control valve is not rebuildable by us amateurs. The cylinders had a rebuild kit some years ago. It was a bunch of orings and a teflon piston seal. The piston seal required a special tool to install it.
Maybe you can find a used PTT unit and cannibalize?
redneck joe
if it is seals, gaskets are old so not sure cannibalize would work.
how could i test to see what the issue is?
To my original question would the link (or some other unit) work? I realize if the rams on the motor are leaking that is an seperate issue.
If the piston seal in the trim cylinder is bad, no pump will make it hold trim. Ditto for the control valve, although, I never had any issue with that item.
You may be able to find an old trim cylinder rebuild kit. It will take some looking. Then you will need to isolate the leaking piston seal to the correct cylinder. This can be done, with some plugs.
If the trim goes up when the motor is in gear and boat is on plane, the pump is likely good. Of course, if the trim cylinder piston seal is real bad, the leak could mask a good trim motor.
I always thought that the PTT cylinders on the 50HP motors were shorter than the ones on the 80/85/90/115/150 HP motor, which I know share trim cylinders. You would need to check this.
You might start investigating whether you could switch out the midsection and transom brackets on your motor for a newer one with the built in PTT.
jimmbo
My motor drops slowly when on trailer and of course faster when under way. Are they semi universal and or how do I fine out what is compatible? Mine has a trailer heater, that does not work ans really don't care but would this work?
Trailer Heater?
Your motor is dropping, so what is with the Transom Button Kit?
There should be plenty of 2nd Hand Parts/complete Systems available
redneck joe
Don't know how heater got in the sentence, was supposed to be trailer setting on the switch.
redneck joe
Yeah everything works, just slowly lowers when on trailer and faster when on the water running so I'm going to go with the cylinders are allowing bypass.
I'll try to figure out a rebuild kit.
jimmbo
Have you got the Factory Service Manual? I used to have one for my Inline 6 and it had a Section for the Power Trim Systems. Included were Drawings of the Hydraulic Systems
redneck joe
This appears to be the one I need?
jimmbo
Looking at the Table of Contents, to me, it looks like a Selock/Clymer Manual. My Factory Manuals
I would trust this manual far more
redneck joe
just ordered, glad it didn't sell.
It even had a pic of the manual open to the TnT section... :)
