2004 searay
- Jun 30, 2023
- 65
2000 dp-sm outdrive, i am trying to make a tool and if these threads are a pipe thread, for the inner prop, i may be in better shape than i thought.,
any idea what type of thread it would be ?no prop nut is a pipe thread
no, i didnt. from what i read, that tool screws onto the outer shaft and you use a bolt through the center of the tool to tighten against the inner shaft which pulls the outer shaft and carrier from the case. no?You know the inner and outer shafts come out as an assembly prior to separating them.
