Tafflad
- Oct 23, 2007
- 545
I posted previoulsy about corossion issues requiring replacement of VP drive.
forums.iboats.com
I have a VP 280 C-N engine with DPS drive, posted here of serious corrosion on the drive with is on a non-moored boat.
VP replaced it under warranty ….. after only 5 trips out the paint was corroding badly again. At any corners or at bolt holes, corrosion was under paint like a spiders web various photographs and VP even sent their Product Specialist to my house to inspect the drive.
Initially it was assumed some form of paint application process issue … they were to paint and refit.
Today they fitted an other new drive, the third one, and boat only done 110 Hrs.
This time the drive is the new OCEANX variant.
Web site quotes “the durable titanium-ceramic OceanX coating, which is applied using a state-of-the-art electrodeposition process and covers the entire drive assembly, makes the Volvo Penta drives four times more resistant to galvanic corrosion."
Very strange that it corroded when out of the water.
VP confirm all bonding is 100% correct, and added that anodes only protect when in weather so no effect when out.
I fresh water flush on muffs and wash outside after every use ….. unsure whether I should look to spray and de-watering lubricant (like WD40) or similar - have asked VP for advice.
280 C-N. Corrosion
Volvo Penta drive exchange. (Detailed in previous post) Finally after 14 months of waiting my new DPS drive has been fitted. The ‘old’ one had severe corrosion, I had spotted this initially on bearing carrier, and that is what I reported in Aug 2021 First dealer took boat in, after 5 weeks of...
forums.iboats.com
