I'm getting no power to the fuel pump, if I put direct power to the fuel pump it will run. Engine starts after pumping the throttle several times and stays running obviously until gas runs out.
I checked power at green wire on the alternator and I am getting 12V. I checked power to the green wire going into the fuel pump fuse holder and I do not have any voltage. The orange wire I am getting 12V to it. The black negative wire going to the relay holder I am getting 12V.
I looked at some diagrams and it shows that the green wire is supposed to go from the relay holder straight to the alternator but it did not look to be going there. I took off almost all the electrical tape and it looks like they are separate.
I just bought this boat and the electrical was a bit of a mess with some wires having been open which I redid the connections to see if that was the issue which it was not.
I replaced the relay as well and did not make a difference.
I spent a few hours trying to figure it out and I don't recall if I tested whether or not the negative wire going to the fuel pump. The 15 amp breaker I checked as well and there's 12V going to both terminals.
I tested the wires both in the start position and when I was cranking it and there was no voltage going to the red/yellow wire to the fuel pump or the green wire going to the relay holder for the fuel pump.
