building a mini speedboat
samleen18
I'm making a mini speedboat/fishing vessel as a fun project and want to build in a center console with steering wheel, seat and throttle. It is an Avon rover r2.80 with an evinrude 9.9 (shaft rated), inflatable keel, and electric trolling motor. I am also going to install fishing pole holders and a mid mounted 10 gallon fuel tank/battery/inverter holder. what do you guys think? Its main use will be hopping around the san juan islands for camping.
mr 88
So your not making anything, just adding stuff onto a RIB . Usually a inverter, 12 volt to 110 , drains the battery big time . Something I would forgo with the limited space you have . Other than that, it's your boat , customize it any way you want .
samleen18
I am modifying the transom to possibly take twin 9.9 engines. the entire deck will be redone by me in aluminum
Sprig
Looks like a fun boat but it’s not what I would want for cruising around the sound. That’s big water, gets rough out there when the winds blow. I’d stick to calm days and head for shore when the winds start.
cyclops222
A inflatable keel adds a lot of drag ? Going to be a no free space to move around in boat.
My 16' Aluminum is snug. I have laid on the bottom during a high wind squall. Did not feel safe.
Sprig
Hate to say it but I think the OP is a youngster with a small inflatable , an old motor and grandiose but impossible plans and dreams. The ”project” makes absolutely no sense. If I’m wrong i apologize to the OP.
samleen18
No way would I be adding a aluminum deck on that . How would you safely secure it for starters . What's the purpose of it ? Trying to make a houseboat out of a kayak . Hold my beer .
it is a multi piece deck bolted to the transom to replace the water damaged wood one that only uses compressing against the rails. same basic design.
samleen18
I have the design drawn up in CAD. the aluminum deck will bolt in to the transom to provide the extra structure needed to support the weight . the original deck just uses tension/compression
samleen18
I am aware of it making no sense. I'm just having fun with the things I have. I am a relative youngster as I am turning 19 this month
samleen18
I designed a rental wood row boat to do 30 mph. Water logged. Made no difference to me then.
I was 13 ? 1950 ?
I dreamed up more gadgets than a Swiss Pocket knife. :)
I have always made inventions since I could hold a wrench. I am 19 this month. don't worry, I already have all of my safety gear (marine radio, PFD, flare gun with marine flares, emergency strobe, air horn, patch kit, tool kit, spare parts, first aid kit, emergency blanket, extra clothes in a dry bag, electric motor) the Puget sound is no joke sometimes
samleen18
I would not say "trouble", but certainly a lawyer's dream come true....
I agree. I am getting my boat re certified by the coast guard when I am done with my structural modifications which include trim tabs, bolting the deck to the transom, gussets for the transom. definitely sticking with my trusty 9.9 and not going over due to legal and safety reasons
every pound of weight you add to the boat takes away what you can put in the boat. so adding a deck, means you dont bring fishing gear, etc.
the weight carrying capacity is determined by testing, or by the CFR 33, part 183. https://www.ecfr.gov/current/title-33/chapter-I/subchapter-S/part-183
you cant carry more weight then listed
