Water in Oil
bullhead93
Mercruiser Model MCM 4.3 EFI ENGINE 0M090084
Water in crankcase remove spark plugs water came out of cylinders 6,4,3, removed oil add new.Did a compression test on cylinders 6,4,2 i have 240 psi on cylinders 5,3,1 i have 190
I've rebuilt a few engines work on many cars but not to good on trouble shooting im thinking hopefully blown head gasket would like to understand what happen my first boat
ESGWheel
Can you provide the history of this motor and what was going one prior to this discovery of water in the oil. Example it overheated and had to be towed home, etc.
bullhead93
me and wife retired sold house moved to bullhead city bought it off a older gentleman said he was the second owner and and its alsways been in his garage said he he he did all the maintenance himself change fuilds etc. said he was a mechanic in the air force said it been sitting in his garage 1 1/2 years he does get around every good he took real good care of it told me he would take us out to the lake i look at the motor check oil and fuilds eveything look good we went out next morning couple hours on lake look over at one time he look tired we bought he took it to our house i drove him home and the wife fellow he didnt look so good the next day i put a removable tongue on trailer thought i would change oil and here we are.I did call him and he felt felt bad wanted to give money back i told him maybe it was just a blown head gasket said keep receipts
ESGWheel
Thanks for the background. Frankly I am having trouble connecting the dots.
  • Dot 1 > oil looks good and took it for a test drive, all is fine
  • Dot 2 > Put it on the trailer and took it home
  • Dot 3 > Decided to change oil and found water in the oil and stbd side cylinders.
What I am struggling with is between Dots 2 and 3 > it seems improbable that at the last minute of the test drive - when putting it on the trailer - there was a failure that went unnoticed that introduced water into these areas. While possible, it just seems unlikely.
Was the oil when you checked it and discovered water all milky? This would be an indication there has been water in the oil when the motor has been run.
In terms of troubleshooting (T/S) and getting to root cause, it could be as bad as a cracked head or block, a cracked riser or manifold or a blown head gasket. While one T/S technique is to pressure test the water jacket its not so simple. Easier to pull off first the riser and then the manifold and inspect these for cracks or internal rust ‘holes’. Thus, suggest start there. If all looks good, then you are into pulling the head.
Also, the compression test numbers are way too high so there is probably something wrong with the gauge.
any cranking compression way above 150 is either water or oil in the cylinders, or a bad gauge.
verify your gauge, however I bet if you pulled all the plugs and turned over, you will find that water comes out cylinders, 2, 4, and 6
all bad on one side would indicated cracked manifold or failed riser
was this a slip-kept boat, or was the boat just not winterized properly
nearly never a blown head gasket.
Lou C
Is this one of the Merc 4.3s with the one piece exhaust manifolds (‘96-‘99), if so these are known for failure & leaking water back into the cyls. There are conversion kits to convert those to the conventional 2 piece style….
bullhead93
First and foremost, I want to thank you all i've read all your post .I took of exhaust manifolds did'nt see anything so off came intake manifold. I could see on number 6 cylinder water was getting in to intake went back to exhaust look at it carefully and found a hole the size of a pencil eraser in number six cylinder.
Everyone who reply to my post said exhaust or intake if i had'nt come across this forum and you all i would've went to the heads .once again THANK YOU.
L
bullhead93
Lou C yes it is a one piece manifold and There is conversion kit can any of you tell me of a place i might find the pair from what i'm seeing it not going cheap.Welcome to the world of boating.
Lou C
Merc makes an OEM kit, and Barr Marine makes an aftermarket kit, I have used Barr with good results on my OMC, which also had the one piece V6 exhaust although I never had water leaks from those, but they were NLA when it was time to replace them....
Here's a link to a place selling the Barr version....
Not cheap but it has everything you need to convert. No one except GLM made a kit for my engine (OMC) but due to GLMs lousy rep at that time (don't know if it's better now) I elected to put my own together from Barr Marine's OMC/Volvo manifold & elbow kit with additional OMC/Volvo parts needed to convert to the later style. And at the time I think the total cost was about $1200, but that was like 8 years ago. It all fit like factory with no leaks. The cost, well it is what it is. Bad marine exhaust has killed many inboard engines!
ESGWheel
Well, this is good news that you found the issue. While I like to try to help, I am also trying to learn. I am a ‘lifelong learner’ as they say. As such I am not familiar with the one-piece manifold and riser so could you please post a picture of it? Also, I would be interested in the cylinder 6 hole > can u post a picture of that as well?
Also agree with using Barr, I did, and am happy with them. Also see this post on replacing manifold and risers for some tips and ticks link.
Barr is one of the casting houses for Volvo Penta, Mercruiser, PCM and others aw well as Edelbrock. So they have pretty good stuff.
The batwings were a bad idea dreamed up by accounting. Core shift meant the walls were either paper thin or really thick they only lasted a few years in production
bullhead93
one more question are there certain things i need to do with motor after a day at the lake and is the propeller suppose to have 1/4 in free play
Lou C
I recall reading somewhere that when GM bought out the Vortec V6s the engines cost l more they came up with this idea to save money. OMC also had their own version of the one piece batwing from 1985-1990 on the V6, I had 3 sets of those on mine (salt water use, changed every 5/7 seasons) and never had a leak on any of them.
ESGWheel
Thanks for the picture. Odd that hole did not hole did not rear its ugly head during the test run as it looks like it’s been there for a while. And Lou’s link had a picture of the older style ‘batwing’ so good there too.
Please define what you mean by free play: axial or radial. See pic for definition if needed.
ESGWheel
one more question are there certain things i need to do with motor after a day at the lake,,,
The most conservative thing to do is to flush the engine on muffs or the flushing port is equipped. While you are in a lake and can probably get away without doing this except at the end of the season, flushing certainly only helps and cannot hurt. Run the engine at idle until running temp is reached (to open the t-stat). Sometimes this may take a while and I have read where the owner walks away from an engine running on muffs only to come back and find the muffs fell off and now a ruined engine. So stary with the boat.
ESGWheel
Follow up: If you are not going to pull the motor and do a rebuild suggest doing the following as soon as possible if you have not already:
With the high-tension lead to the distributor grounded out and all spark plugs removed:
  • Crank the motor to ensure all the water in the cylinders is pushed out
  • With a large can of WD40 spray a healthy dosage of it into each cylinder
  • Turn over the engine by hand a couple of times
  • Then crank the motor again using the starter which will spit out that WD40 so may want to have lots of towels spread out
  • Then repeat healthy dosage of WD40 into each cylinder and turn over twice by hand.
This will help preclude any cylinders or rings rusting out while you get the replacement parts to get the motor running again and dry it out.
