Scott06
- Apr 20, 2014
- 7,376
Yes you can cut it off just take care on the inner race not to cut into drive shaftNot making much progress with a hammer. Can I cut this off or grind it off?View attachment 407905
If you were changing the u joints yes take the yoke off put it in a $100 harbor freight press and it will come off with out damaging anythingBe much easier with that yoke removed. I'd probably try supporting the aft end of the bearing vertically in a vice and hammering the yoke from above with a 2x4 on top. Not sure how that would treat the splines though.
If the gimbal is frozen to the shaft probably not a bad idea to do the ujoints anyway. I really need to buy a press. I just got a drill press, and it's like magic. I'm so damn short on storage space though...If you were changing the u joints yes take the yoke off put it in a $100 harbor freight press and it will come off with out damaging anything
The press is well worth the investment
Yeah I put mine on wheels but fervently stub my toes on it. I bought mine for rebuilding the suspension and changing rear gears on my gto. Was right there when rebuilding jet pump on the seadoo and doing seals and bearings on my outdrive. For all the work you do it’s worth it.If the gimbal is frozen to the shaft probably not a bad idea to do the ujoints anyway. I really need to buy a press. I just got a drill press, and it's like magic. I'm so damn short on storage space though...
