Ricky_rich
- Mar 4, 2014
- 147
My guess is that engine is not getting enough fuel. Where would you start looking for the fault?
Sounds like your dropping a cylinder(s)View attachment 408423I have a strange problem with my engine. Sometimes I loose power, the 200hp feels like 5hp even with full throttle. If I put it in neutral I can rev the engine and think it sounds good. But with gear in there is no power. And then all of a sudden things are working, and I can get the boat to plane and go really fast. And then power is lost.
Testa done now with these results.Sounds like your dropping a cylinder(s)
Compression, spark and fuel pressure test
No… but a bad /failing high pressure fuel pump will cause all kinds of issues with an EFIWould it be possible for the engine to run even without fuel pressure from the electric pump?
Yesterday I was out testing the engine, run fine for about 30 minuters, I was starting to think that the problem was gone, but no. Lost all power, could not get the boat to plane. 200 hp turned into 2hp.No… but a bad /failing high pressure fuel pump will cause all kinds of issues with an EFI
Fuel rail hold pressure at shut down or immediately go to 0?
Running a 10 micron fuel filter?
Cleaned the VST?
When is the last time you had the injectors cleaned?
Missed the last question.Yesterday I was out testing the engine, run fine for about 30 minuters, I was starting to think that the problem was gone, but no. Lost all power, could not get the boat to plane. 200 hp turned into 2hp.
A new 10 micron filter installed.
Fuel rail hold dont drop to 0 when turned off, have to check again how fast it drops.
I have not opened the VST, guess I should have a look at it.
I have changed cable, and coil. There is no distributor on my engine, CDI ignito.Arcing in H V wiring to plugs. Or carbon track inside distributor cap at that plug location.
