Capt dave 258
- Jul 14, 2021
- 74
Recently picked up a 1971 Evinrude 60hp, model #60173C. I have no history on it. Motor turns over freely with about 150 compression on all cylinders. Motor has no spark. I've replaced the coil and cleaned and gapped the points to .010. I've tried starting the motor by disconnecting the round, main wiring harness and jumping the starter. Still no spark. I'm told that eliminates the potential of a bad ignition. I've tested the amplifier with a test light by hooking up one lead of the light to ground and the other to the blue wire for the amplifier. As I crank the motor the test light comes on so I'm guessing the amplifier is good. The plugs are the type that you don't gap. They look clean and fresh. The motor is overall very clean and all wires are in good shape with no signs of corrosion. Battery is new and cables look in good shape. What should I be testing next and how can I go about doing so? I've read most anything on this forum that I could find in regards to this motor and no spark issue. I'm not prepared to dump much money into this motor as I don't really need it. Any suggestions are appreciated. Thanks
