Lower gear oil drain plug seal for Johnson outboard
Robbyracks
Hey folks,
I have a 1990 50 HP Johnson (VJ50TLESR). What size seal should i be using? I believe the 3/8-16 is the correct size but I just want to confirm before I order them on Amazon. Thank you!
3/8-16 is a spec for a bolt. Is that what you are asking?
I would expect you could ask for a generic J/E plug. Don't forget the fiber gasket.
Robbyracks
Specifically referring to the little blue seals that sit between the bolt and the port of the gear case. TY
Those blue seals are avail on Amazon, as well as a lot of places. Just order Johnnyrude or Mercury ones. They are the same. Yammies are a bit smaller.
Robbyracks
Can't order from US Amazon.. Here is a Canadian Amazon seal - will this work?
Seals
I use a hand impact driver to tighten the gearcase plugs. If you are strong and have a big, slotted screwdriver, you can tighten by hand.
cyclops222
DO not use any impact. The washers can be squashed & leak.
Those seals should last at least 20 years. Mine are much older.
airshot
I made a large flat blade on a screwdriver that has a square shaft. The blade fits the slot very well and the square shaft allows for a little extra leverage. Made it years back and seems to fit alk the gear case screw slots.
airshot
A cast aluminum housing is not a good place to use an impact tool. Better off to make a tool that works with no sharp impact.
Mc Tool
Ensign
🙄 just google " evinrude/johnson gearcase drain plug "
I got ½ dozen with sealing washers off timu for a couple of bucks .
They fit my 6hp zuki, 35hp Honda and the Tohatsu m18
Really? I have been using a hand impact tool for 40 years on my gearcase screws. Tighten the screw, and then tap the impact driver to tighten it a bit more, maybe 1/4 turn. My gearcase plug washers last exactly 1 season, not 20 years.
JohnnyGuy
The impact just isn't needed. What you can tighten to by hand is sufficient. Using the impact increases risk of damage, not to say that it will damage it, but it certainly increases the risk.
Does anyone realize that a hand impact driver uses my hand and a hammer? I suppose I could damage the gearcase threads, if I got a BFH and wailed on it. That is what it would take.
I, for one, do not want the gearcase plugs to work loose over the season. That will ruin the gearcase for sure.....
airshot
Some folks realize what a tap is, while others might use a 20# sludge hammer ! When the word "impact driver" to a person not familiar with these types of tools gets carried away, ugly things can happen.
Gee, that is why I said "Hand Impact Driver", vs "Air Impact Driver".
Does anyone not know what a BFH is? I will save time. it is a big hammer.
airshot
How many in this country do not do any type of maintenance or repair anymore ???? How many don't even own tools ?
Mc Tool
Ensign
Haven't done this myself but a friend who suffers paranoia about drain plugs with nylon (or whatever they are ) sealing washers and he dunks them ( the screw and washer ) in a cup of boiling water to soften them just before installing them and then hand tightens them wth the bf screwdriver.
I think the washer not only seals but also acts as a sort of friction lock .
I dont think there is any correlation between the likelihood of a fastener coming undone by itself and the potential disaster if it does . If you do it right the drain plug is no more likely to "fall out " than a head stud .🙂
