rjcamel2355
- Apr 22, 2015
- 225
Hey folks, I have an early 80's blackmax 150HP (I believe it's an XR2), all the usual tricks haven't worked.
1. Cleaned carburetors, double and triple checked.
2. Compression (cheap china gauge) is 85-95PSI on every cylinder
3. New water pump, new lower unit oil
4. New switch box (Had no fire on 1,3 and 5) *It now has spark jumps 7/16"+ on all 6 plugs
Engine runs fine on the hose, starts easy and idles great, shifts in and out of gear, and revs on a hose.
1. Engine idles high when put in the water dies when shifted into gear (forward or reverse)
2. #3 spark plug is black after running (Double checked compression, and spark, both are good), triple checked the carburetor.
3. All other plugs look normal, not black, not fouled.
4. Tons of white smoke when lower is submerged and running.
5. Engine will rev in neutral (in the water), but shift into gear and it will die, bumping up idle does not help.
Any ideas? Thinking a possible powerhead gasket, with the white smoke and not wanting to run with the lower submerged (load on engine).
