Saying put a hydrofoil on it and/or trim tabs. They're putting the SE300 on ALL their VR5s new. warranty isn't covering anything to do with this weakling boat. even with the 15 pitch prop it has trouble pulling my 180lbs son up on a slalom (he just learned though!).So, what did they say at the dealer? Anything interesting?
You should try the 15” or 16” prop I ran a 4 blade 16” on my 3.0 powered boat made a big diff in water starts. I also had a hydrofoil that helped until it snapped the cav plate.So, like my previous post said, (post is closed for some reason).
I've since tried a 3 blade 17 pitch and a 4 blade 17 pitch prop. I can't really tell the difference.
I'm now 210lbs, trying to get up on a slalom ski with 2 adults and one child, their combined weight is like 460lbs, all except the 180lb driver are in the bow.
Takes about 45 seconds or longer to get me up. Trim all the way down, minimal stuff in the boat.
I'm about to try a 15 or 16 pitch 4 blade if I can find one soon enough.
Related side note: All the VR5 bayliners I see at the dealer have a hydrofoil installed. This boat feels like it has about 120hp. If it's just 2 people, 390 lbs cruising in the boat it is just slow as hell, largely due to the bow pointing so high and taking so long to plane.
Here are my "results":
Me and a friend, about 360lbs:
Factory 3 blade 19 pitch:
46mph @ 4800 rpm, trim "optimized for speed"
41.5 mph with trim all the way down 4450 rpm.
0 - 20mph 6.0 seconds
0 -30mph 9.4 seconds
3 blade 17 pitch:
43mph @ 4810 rpm with trim up
41.5mph @ 4450 rpm with trim all the way down.
0 - 20 mph no change
0 - 30 mph 9.2 (no real change)
At this point, I'm not sure what I'm going to do. I don't think I can mentally handle the $30kish I'll lose by trading it in and getting a real ski boat, or a boat that is ~20ish foot with a MINIMUM of 300hp.
I didn't realize that $50k would not buy me a boat that I could ski behind. I've skiied behind 19.5' boats with 120hp outboard, and a 135hp inboard. The 120hp boat pulls me up like this 200 horsepower boat. the 135hp boat pulled me up in like 20 seconds or less.
This is ridiculous. Bayliner should make sure they label this wakeboard boat as not a water sports boat. It's OK for wake boarding and good for tubing, and cruising around, that's it.
Yes I think I had it on for 8 years or so. This was the older design where you drill 2 holes in cav plate , cracked right at the holes. Boat was fresh water its entire life alph gen one drive .Also, to address a couple of people's comments.
When I took to the dealer, they checked for codes and engine issues, none found.
The swim deck has drain holes in it, I do see water draining from them often, so water does get in there... not sure if water is getting in from those holes, you'd think it would be water tight (without the holes).
And Scott... you're hydrofoil snapped the cavitation plate?!!?! More details please. How old was boat? used in salt water? How big of a boat?
The service guy at bayliner said the VR5 has this issue because the bow is so light. He said the VR6s do not have this issue... find that hard to believe, but after this weekend, I'm considering buying a couple of 50lbs ballast bags to put in bow for when not very many people on the boat
If the prop was bent it will always vibrate just get worse as the rpms increase. I wouldn't worry how many hours on the motor?I am noticing a little carbon build up on the propeller shaft, is that a problem?
Also, I do get a little vibration at certain rims. I think around 2k, wondering if the propeller has bent or something. I do see a little paint peeling off.
Carbon build up on propeller shaft
2025 bayliner vr5 with about 55 hours on it. 4.5 liter 200hp mercruiser with alpha one stem drive. I've been trying different props to pull me up on a slalom ski. Finally got that going well after 4th prop. This is a 15" 15 pitch 3 blade EMP propeller. Boat goes 39.5 to 40mph at around...forums.iboats.com
Regarding the hours on the motor, I was referring to the carbon build up and the fact that I had the 100 hour serviceIf the prop was bent it will always vibrate just get worse as the rpms increase. I wouldn't worry how many hours on the motor?
What brand did you buy? Did you install? I'm going to pay big to get them put in I'm assuming.The advantage of hydraulic trim tabs is that if properly installed, when retracted, they are well above the transom/hull point and do not drag. When extended, they will really lift the transom. So, on an underpowered or tail heavy boat, tabs down for takeoff, then pull them up. If heavy seas, trim motor down, trim tabs down until ride is smooth.
With my '88 SR 19 footer, 4.3LX (205HP) MerCruiser and 8 people in the boat, pulling a skier. put tabs down, fill the bow with people, hit the throttle and wait a few seconds. Now lift the tabs, move people to rear of boat and enjoy.
