Paradise pontoon
- Jun 27, 2023
- 42
Hello i have been working hard on a 3.0L mercruiser with HEI distributor. Had it running to set valves, installed everything back now no ignition! Purple wire going to coil is 12 volts with key on and cracking. White/ Green wire is 12 volts to distributor. Distributor is ground to engine good, module to distributor is also has a good ground. I installed new electronic module, new pickup coil , new coil, new rotor, new cap , new spark plug wires ( ohmmeter wires out) check good, new spark plugs, checked over and over connections,disconnected the tach wire, what im I missing?! Coil has good ground. Battery has 14.5 volts plenty of voltage. Replaced all battery cables positive and negative. Cleaned ground area. TIA
