Tried to take the boat out yesterday for the first time and realized I could not get it to trim all the way up or down. Checked the fluid and it was low so I added some and did the 5x up and down to bleed it. Unit would still not go all the way down, was acting like it was hung up on something. Decided to check and see if it was the unit or the cylinders/pump. Unhooked one side and a time and ran it through a cycle. Left side went all the way up and down no problem. Right side will not go all the way down, gets to within the last couple inches and the cylinder acts like it is plugged/jammed.
Both the cylinder and pump are stupid expensive units. Any way to tell for sure if the pump for that cylinder is bad or if there is something wrong with the cylinder? Any other things I might be missing that it could be?
