No more boats
- May 4, 2023
- 74
2000
Yamaha OX 66
2 stroke
250 hp
SX250TXRY
PART # 65L13183-00-00
This part is the check valve in the oil line going too VST tank
Had back flow of fuel into oil reservoir.
float not stuck
can blow air thru both sides of check valve , plus cleaner when spayed in comes out both sides ,
called around , nobody has this part and Yamaha has it back ordered with no time line of when it will be available
this is not uncommon
what have others done too go auto parts and find the correct substitute ,
not eager too by pass oil pump and put oil into tank
thanks
Yamaha OX 66
2 stroke
250 hp
SX250TXRY
float not stuck
thanks
