oldfarmall
- Jun 18, 2009
- 66
Hello-
I have a pre alpha Mercruiser stern drive unit on a 1974 Glastron boat with a 140hp inboard. I am going through the lower unit to replace all the seals. My shift shaft is corroded and rusty where the shift shaft seal would ride, so it will need to be replaced. I purchased a new shift shaft. Can I simply pull the shaft out and replace it, or do I need to take the carrier assembly for the prop shaft and driveshaft pinion out to remove it? Is there a procedure to pulling it straight out without removing the guts of the lower gearcase? Seems like I am getting resistance when pulling up on it. Thanks!
-Jesse
-Jesse
