5)Appears to me I’m losing power between the key and the coil. I’d like to look at the connections at the kill switch but I don’t know how to get it apart without wrecking it.
Ayuh,........ Is there ignition power(purple) at the big cannon plug, where the boat meets the motor, when the key is "On",..??
Rather that takin' a chance on breaking that switch, any chance you can see the wiring behind that panel,..??
There should be a red, a green, 'n blue wires for the trim,....
a yellow/red wire to the neutral safety switch, 'n back to the harness,....
'n of course the purple wire up to the kill switch, 'n back to the aft harness,....
