Why is it deleted? I saw on the rules a mention of photo upload tutorial. However, when I click to view, I get permission denied. I did reduce the size of the images, were they still too big? Thanks.deleted
From lack of use, the motor is not running well at idle. Smooth for a few seconds, then stumbles for a few seconds, the pattern repeats itself. I think I'm dealing with a fuel delivery issue to one of the carbs, most likely the upper one. When priming, I noticed fuel leakage at the coupling, so I ordered new o-rings for that. I also saw someone comment that the fuel diaphragm should be replaced periodically, so I ordered that too. With the cover off, I happened to see this part laying at the bottom of the compartment, below the carbs. No clue what it is or where it fell off from.Pic showed up just fine.
The part?? No idea
What were you working on that you found that part??
